pricear's avatar
pricear
Looking for compatible wired router or how to make the current one work!
Hi - I'm interested in getting a wired (non-wifi) router that will not degrade my high speed internet signal from Xfinity (Pittsburgh) and that is compatible with my CM1000 modem. I purchased an inex...
  • FURRYe38's avatar
    Not sure if NG has any wired only routers anymore. They mostly make routers with WiFi.
    I now that Ubiquity has wired only routers. You might look into the Edge Router X.
