Kakashi2000's avatar
May 18, 2016
Make for modem and routers
Add cpu protection =hakers use to attack and the attack are invisible but attack cpu and cpu soket or network
Add memory protection prevent attack slow down your pc
Add keyloger protection
Add Web cam attack protection
Add port exploit or holes protection
Add hiden chanel port protection
Add anti bypass firewall
Make firewall kill junks and virus by defence and don't slow down speed or performance ect
Add a extreme security for ready share this is risk
Fix upnp some times not register or Un register device and get gish
Fix control block some times get gish and devices get disconnected an conected fix that
Fix lan some times don't detect devices
Ect just helping
1 Reply
  • Update your firewall I was reading that hakers black hat create malware are or software to lean how the firewall works and them hack it or by pass it or copy it and fool the firewall make it like good traffic fix that and make firewall random uknow to lean how the firewall work's
    Ect
