MStepan
Jan 19, 2018Aspirant
Making use of a router after a move
OK, I bought the C6300 router when I moved into my house and it worked and did the job fine. Now I've moved to a condo where internet is supplied, so while I no longer need all of the functionality o...
antinode
Jan 19, 2018Guru
> [...] I WOULD like to leverage the WiFi and the Hub/Switch components.
With no exposed WAN/Internet port, it's not much use as a normal
router, but that much should be possible. One attempt at step-by-step:
https://community.netgear.com/t5/x/x/m-p/1463500
> How would I do effectively the same thing with this NetGear box?
Pretty much the same way way as with anyone else's router?
- MStepanJan 19, 2018Aspirant
Thanks! I'll give that a try when I can (over the weekend). That's along the lines of what I was trying last night, but not being super-familiar with the NetGear "gear", I was mostly just snooping. I'll report back after I give it a whirl ...
