yasirfaheem's avatar
Jan 23, 2024
Maximum download and upload speed of the cm1200 cable modem?
What is the maximum download and upload speed of the cm1200 cable modem?  I have Comcast and am paying for 800mbps download and 100mbps upload.  When I have the cable modem connected directly to my computer and run a speed test I get 950mbps download and 25mpbs upload.  I can never get the full 100mbps upload that Comcast says I should be getting.
  • FURRYe38's avatar
    I would presume 100Mpbs on the up should be there since WAN ports support 1Gb.
    Last time I had mine online I only saw 50mbps however tha'ts all my ISP supports, even currently.
    Please post a copy and paste of the modems connection status and event log page.
    https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
    https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What is the brand and model of the host wifi router connected to the modem?
    Have you connected a wired PC directly to the back of the modem with out any wifi router in the middle to check speeds?
    Test with a different wired PC to compare results?
    What speed test app are you using? Recommend using Ooklas installable speed test app rather than the web based version.
    Using your CM1200, you will not see the 100 Mbps upload on the Comcast Enhanced Speed network.  The CM1200 is not on the Comcast list of certified customer owned modems allowed to connect to the Enhanced Speed network.  For the current list, see the attached screen snip.
    For further details, refer to the Comcast_Xfinity sub-forum on Reddit here:
    https://www.reddit.com/r/Comcast_Xfinity/wiki/knowledgebase/next-generation-internet/.
