netmation
Apr 20, 2024Aspirant
Mid/High-Split modems affecting TV Cable Pixels Reception?
This past year, I was using the Xfinity XB8 modem which utilized the newer enhanced Xfinity Mid/High-Split spectrum (32x8) allocation in DOCSIS. As advertised saw my upload speed go to over 120 Mbps...
Apr 21, 2024Guru - Experienced User
If you want the higher speed tier, the CM3000 supports that. The CM2000 we are unsure about if that will be supported.
However if you have cable TV, you should contact the ISP about that since I believe that service runs up to a different TV box which maybe there could be some TV signaling problems with that the ISP should resolved. Cable TV and Internet services are mostly separate coax cable lines. Uness you do some streaming thru the internet services which would come thru the CM2000. We can help you check signaling on the CM2000 modem to see if there could be issues there, however if your not seeing any problems with the internet services, something on the cable TV side maybe effected by the ISPs change in there services. Something to contact them about.
- netmationApr 21, 2024Aspirant
Yes, the CM2000 does not provide the enhanced upload speeds. Would love to contact someone at the ISP to discuss the issue, but for a consumer to be put in touch with a Network Engineer who would understand the issue is difficult at best.
Have had some in discussion groups though convey that it is a known problem, but no other information. Thanks for your reply.
- FURRYe38Apr 21, 2024Guru - Experienced User
Well the ISP should be resolving any Cable TV issues and any Internet signal issues up to the modem side.
Something to ask the ISP for escalated support for if your having Cable TV issues.
The ISP has been doing lots of changes over past couple of years and could be something there doing maybe causing problems. Something to ask them about on the phone.
