5MissingOnOne's avatar
May 15, 2018
Missing 5 GHz
I have 3 devices connected but one of them can't see the 5 GHz setting. - HP ENVY dv7 Notebook PC
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Have you checked the networks saved by that PC and clear them?
    DarrenM
    • 5MissingOnOne's avatar
      5MissingOnOne
      Yes and they have been cleared.  I see the 2.4 and I can hook up to that, but I can't find the 5.0.
      One two other mobile devices, I can see and I use, the 5.0 channel.
      • DarrenM's avatar
        DarrenM
        You could try to change the SSID on the 5ghz network just to troubleshoot see if it shows up.
        DarrenM
