icenpcgiuli
Aug 03, 2018Follower
Missing Menu Options on Modem Web Browser Login
Hello! I've been trying to portfoward and I am unable to access the full menu of my router in a web browser in the Windows 10 environment. The portfowarding tutorials I've read online all use router...
antinode
Aug 03, 2018Guru
> [...] The portfowarding tutorials I've read online all use router
> logons with more options in their web browsers, and I am having great
> difficulty port fowarding without these options. Now, my family uses the
> CM600, [...]
The CM600 is a cable modem. Port forwarding is a router function,
not a modem function.
> [...] but we also use several Apple-brand wifi devices such as the
> Airport Express. [...]
That's a router, and that's where you'd need to configure port
forwarding. (If "such as" means that you have multiple routers, then
you can expect some problems with port forwarding.)
> [...] I've included screencaps of the modem menus as they are now.
In-line images in these forums must wait for moderator approval, so I
can't see yours yet. But if they relate to the CM600, then they're
likely irrelevant.
