Bevie12's avatar
Bevie12
Follower
Oct 03, 2022
Model C3000
My modem is online and shows connected to the TV but none of the Apps work.  I cannot connect my phone either but my laptop is connected and working.  Any suggestions as to why my phone or TV are not working and steps that I can take to correct or if my only option is to buy a new modem.
1 Reply
  • FURRYe38's avatar
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
