chipforex101
Apr 08, 2026Aspirant
model CAX30 Netflix will not connect
Hello, Looking to see if there are any reported issues with nighthawk router after a power interruption . Seems Something is not allowing it to load Netflix. Keep getting connection failed code...
chipforex101
May 07, 2026Aspirant
Thank you everyone for your help. Seems to be connecting fine on its own now. A total mystery.
May 07, 2026Guru - Experienced User
Glad something worked out.
Enjoy. 📡
