FrosttheVII
Aug 29, 2018Aspirant
Model CM1000 VDSL or ADSL support?(CenturyLinkSupport)
Hi, I was planning on buying this device but I couldn't find if it was VDSL or ADSL compatible and that's what CenturyLink needed to know to see if it was or not. Thanks in advance!
Aug 29, 2018Guru - Experienced User
FYI, the C in CM is for Cable, thus Cable modem, thus not DSL support.
D in DM is for DSL, thus DSL modem, thus DSL supported.
- FrosttheVIIAug 29, 2018Aspirant
Fer sure, I just needed to make sure because no matter what I'll have to get a cable modem to convey between my coaxial input and my actual Netgear router so I'd assumed that getting the CM1000 would work for that. Am I wrong in thinking this?
- FURRYe38Aug 29, 2018Guru - Experienced User
Yes as both DM or CM modems have RJ45 port in back for connections to a PC or a external router.
Just make sure that your ISP fully supports the make and model modem your looking to get into before making the jump.
- antinodeAug 29, 2018Guru
> [...] CM1000 [...]
> [...] I couldn't find if it was VDSL or ADSL compatible [...]
It's neither; its a cable-TV modem, not any kind of DSL modem.
> [...] that's what CenturyLink needed to know [...]
So far as I know, CenturyLink is not a cable-TV ISP, making a CM1000
(or any other cable-TV modem) useless with CenturyLink.
> [...] no matter what I'll have to get a cable modem to convey between
> my coaxial input [...]
_What_ "my coaxial input"? "input" to what? Is CenturyLink giving
you a coaxial _anything_?
> [...] my actual Netgear router [...]
Which is?
> [...] so I'd assumed that getting the CM1000 would work for that.
It might, if you actually had a coaxial cable coming from your
cable-TV ISP. Do you?
> [...] Am I wrong in thinking this?
I'd guess so, but I can't see any of your equipment, and I don't know
what CenturyLink might have told you. I'd also guess that CenturyLink
would be providing some kind of DSL service, not anything where
"coaxial" would appear in the conversation.
> My Setup [...]
Who cares? How is this helpful? (Especially for someone who's likely
to be concerned with DSL service?)
