FrosttheVII
Aug 29, 2018Aspirant
Model CM1000 VDSL or ADSL support?(CenturyLinkSupport)
Hi, I was planning on buying this device but I couldn't find if it was VDSL or ADSL compatible and that's what CenturyLink needed to know to see if it was or not. Thanks in advance!
FrosttheVII
Fer sure, I just needed to make sure because no matter what I'll have to get a cable modem to convey between my coaxial input and my actual Netgear router so I'd assumed that getting the CM1000 would work for that. Am I wrong in thinking this?
Aug 29, 2018Guru - Experienced User
Yes as both DM or CM modems have RJ45 port in back for connections to a PC or a external router.
Just make sure that your ISP fully supports the make and model modem your looking to get into before making the jump.
