FrosttheVII
Aug 29, 2018Aspirant
Model CM1000 VDSL or ADSL support?(CenturyLinkSupport)
Hi, I was planning on buying this device but I couldn't find if it was VDSL or ADSL compatible and that's what CenturyLink needed to know to see if it was or not. Thanks in advance!
FrosttheVII
I've never actually used CenturyLink before. I'm getting them on the 10th and was going to try and have a modem at hand to use for when I do get internet from them. When I had Xfinity it went through a coaxial modem and I had to have a separate router after that. So I assumed that CenturyLink went through coaxial inernet as well but I could be wrong. I guess I'll have to double check on their end.
antinode
Aug 29, 2018Guru
> 10th and was going to try and have a modem at hand [...]
What you need for a modem would depend on your level of service;
slower speeds may use ADSL, higher speeds may use VDSL. If you've
already chosen a service level, then CenturyLink should be telling you
what kind of modem to get.
> [...] When I had Xfinity it went through a coaxial modem [...]
Beacuse Comcast/Xfinity is a cable-TV ISP.
> [...] and I had to have a separate router after that.
With either cable-TV or DSL, you can use either a combined
modem+router, or separate modem and router. Among modern Netgear
models, CMxxx is a cable modem, DMxxx is a DSL modem, Cxxx is a cable
modem+router, and Dxxx is a DSL modem+router. For DSL service,
C<anything> will not be useful.
> [...] So I assumed that CenturyLink went through coaxial inernet as
> well but I could be wrong. [...]
Could be. Regarding "assume", a quick Web search for:
"Desk Set" "never assume"
could be valuable. ( https://www.youtube.com/watch?v=pEoFFYH_m0Q )
> [...] I guess I'll have to double check on their end.
Couldn't hurt. No doubt, they'll be able to provide something.
Whether they'll be willing to suggest a third-party modem(+router) is
another question. If you want to supply your own modem, then it would
help to know the requirements (ADSL/VDSL, bonded channels, and so on).
> > [...] my actual Netgear router [...]
> Which is?
Still wondering.
- FrosttheVIIAug 29, 2018Aspirant
Ok so found out the service is ran through a RJ-11. So I've come to the conclusion I'll inveast in the AC1900(D7000). Thanks for all your constructive feedback, I really appreciate it. The first time talking with CenturyLink they were very vague and asked if my router had VDSL/ADSL which I couldn't find on it that I could tell and when asking about Netgear modems thay gave me their "What modems are compatible" page, which didn't have and Netgear items on it(I stick with Netgear because their devices have always worked well for me so I stick with dependability). So I believe I got it all sorted. thank you all.
