Leaveit65's avatar
Leaveit65
Follower
Sep 03, 2016
Model: WNDR3400v2 and Model Arris DG 860P2 - WIFI/Speed/Security
Hi  Sorry, The second model option ( recommended section has me lost..The tab doesn't show anything that looks familar. My question is: I have the wifi router WNDR3400v2 *and love it! ..Anyhow..My c...
  • DarrenM's avatar
    Sep 06, 2016
    Hello Leaveit65
    Ideally you will want to bridge the arris modem or find a modem only mode in the setting so the 2 routers do not conflict with each other. But yes you should be able to disable the wifi and be just fine.
    DarrenM
