Ish_y
Sep 28, 2017Follower
modem and router
I have the CM700 modem and my router is Nighthawk X4S - AC2600. I’m having a problem with the download and upload speed. I’m supposed to have 300mbps Download speed but only getting 50mbps. And upload...
DarrenM
Oct 03, 2017Sr. NETGEAR Moderator
Hello Ish_y
This sounds like the right codes are not applied to the modem from the ISP to give the correct speeds or there is to much usage in your area causing slower speeds or the cable company requires more channels on the modem to get that speed but if you believe the modem is defective I would suggest contacting support.
http://www.netgear.com/support/contact.aspx
DarrenM
