Vferia's avatar
Vferia
Follower
Jul 31, 2020
MODEM CM1100 CONNECTED TO R6900 WIFI/ROUTER
I just replaced the Motorola Cable Modem with Netgear CM1100. Activated it (xfinity) and got internet connection. I reconnected the  R6900 wifi/router. The problem is only one port has the internet access. Wifi and the other ports are not connected to the internet.
What to do?
1 Reply
  • FURRYe38's avatar
    Factory reset the router and setup from scratch. Review the user manual and installation guide for your model router.
    Please post about any R router series questions in the following forum for your model router:
    https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
    Good Luck.
    What to do?
