chaparroblue's avatar
chaparroblue
Follower
May 07, 2016
MODEM/ROUTER C300 WIFI SIGNAL TOO WEAK
I JUSTINSTALLED MY NEW MODEM/ROUTER C3000 AND THE WIFI SIGNAL APPEARS TOO WEAK I'M UNABLE TOO OPEN WEB PAGES FAST ENOUGH OR SOME OF THEM NOT EVEN OPEN,  I'M I DOING SOMETHING WRONG OR WHAT DO I NEED TO DO TO IMPROVE WIFI SIGNAL?,PLEASE HELP!
  • Retired_Member's avatar
    Retired_Member
    That box is a cheap POS I made the mistake of recommending it to my son in law.  Return it!
  • Run inSSIDer and Acrylic WiFi analyzer and see what the singal level is.  How did you set up the wierless setting?  WMM enabled? picked and seleceted a good channel? Using WPA2 security protocol? What is signal level in db shown on the inSSIDer or Acrylic. Just don' t say "Too weak"
      Retired_Member
      That box is still a cheap POS I made the mistake of recommending it to my son in law.  Return it!
