AlistairPhoenix
Jun 29, 2017Aspirant
Modems rebooting after heavy use
After about 4 cable technicians and many nights of constant failures, I wanted to turn to the internet for answers. In the past month, my modem is constantly rebooting itself after 4 or so hours o...
AlistairPhoenix
Jul 06, 2017Aspirant
Event Log
Time Not Established Critical (3) DHCP failed - RS sent, no RA received
Time Not Established Error (4) Primary lease failed, IPv4 fallback initiated
Jul 4 17:07:10 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Time Not Established Critical (3) No Ranging Response received - T3 time-out
Jul 4 20:11:07 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 4 23:03:26 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 5 04:04:43 2017 Warning (5) Lost MDD Timeout
Jul 5 04:05:42 2017 Critical (3) No Ranging Response received - T3 time-out
Jul 5 04:06:36 2017 Warning (5) Lost MDD Timeout
Jul 5 10:09:15 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 5 14:09:47 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 5 17:56:59 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 5 22:54:27 2017 Warning (5) Lost MDD Timeout
Jul 5 23:18:55 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 6 04:18:12 2017 Warning (5) Lost MDD Timeout
Jul 6 04:29:11 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 6 09:24:55 2017 Warning (5) Lost MDD Timeout
Jul 6 09:43:52 2017 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
- vkdeltaJul 06, 2017NETGEAR Employee Retired
can you please post your powet table as well from the connection page? thank you.
- AlistairPhoenixJul 06, 2017Aspirant
Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables UnCorrectables
1 Locked QAM 256 1 567000000 Hz 8.7 dBmV 35.5 dB 24 686
2 Locked QAM 256 2 573000000 Hz 8.4 dBmV 35.5 dB 19 544
3 Locked QAM 256 3 579000000 Hz 8.2 dBmV 35.4 dB 6 541
4 Locked QAM 256 4 585000000 Hz 8.2 dBmV 35.4 dB 19 733
5 Locked QAM 256 5 591000000 Hz 8.5 dBmV 35.5 dB 29 615
6 Locked QAM 256 6 597000000 Hz 9.0 dBmV 35.5 dB 26 702
7 Locked QAM 256 7 603000000 Hz 9.3 dBmV 35.9 dB 31 651
8 Locked QAM 256 8 609000000 Hz 9.7 dBmV 36.1 dB 33 611Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power1 Locked ATDMA 44 2560 Ksym/sec 21400000 Hz 39.5 dBmV
2 Locked ATDMA 43 2560 Ksym/sec 25000000 Hz 39.8 dBmV
3 Locked ATDMA 42 5120 Ksym/sec 30700000 Hz 40.5 dBmV
4 Locked ATDMA 41 5120 Ksym/sec 37500000 Hz 41.3 dBmV
can you please PM me? we will need some details which you would not be able to post publicly.
thank you. modems going offline is not acceptable (and especially every few hours).
few items noticed in your logs:
1. Power are generally ok. DS is bit hot but it is not a deal breaker.
2. Uncorrectables should be 0 but it is not a big problem since the count is low.
3. US powers levels look OK as well.
4. Event log is messed up:
