burningbird's avatar
burningbird
Follower
Jun 18, 2020
Moving CM600 from Spectrum to XFinity
I have a CM600, currently set up for Spectrum. I'm moving to another state, where I'll be using XFinity.
Should I do a factory reset before attempting to activate with the XFinity? Or just follow the normal activation procedure?
  • Yes. You might have the current ISP disassociate it from there system. Factory reset and then contact the new ISP to have them associate it with there system.
1 Reply
  • FURRYe38's avatar
