LiamD
Oct 23, 2017Aspirant
Multiple Public IP Addresses with CM700 and Comcast XFinity
I have Comcast Xfinity and a CM700. I want to get multiple (two) public addresses so that I can bind each one to a different router/firewall. Comcast says I have to change a setting in the CM700 to d...
- Oct 31, 2017
They should be able to attach 2 modems to your account and then assign each one a IP address no setting would need changed in the modem.
DarrenM
DarrenM
Oct 31, 2017Sr. NETGEAR Moderator
DarrenM
LiamD
Nov 01, 2017Aspirant
I finally did get this answer from Xfinity. You basically need a cable modem for every public IP you want to use.
