Ditas
Jul 09, 2017Aspirant
My C3000/N300 modem lights all blinking
 Hi,     My C3000/N300 modem router lights started blinking and I can't connect it to any computer even using the LAN cable. I have tried to reset it, not working either.  Please help me to fix this p...
Ditas
Jul 10, 2017Aspirant
I turned off the modem, pushed the bottom with a paper clip and turned on the modem, but nothing changed in blinking
michaelkenward
Jul 10, 2017Guru - Experienced User
Ditas wrote:I turned off the modem, pushed the bottom with a paper clip and turned on the modem, but nothing changed in blinking
That's won't do anything. Use the paper clip with the device turned on.
Or do it from within the device's web interface.
