merncar
Sep 25, 2020Aspirant
My C3700v2 runs 5ghz but not 2.4 ghz.
How can I get 2.4ghz not working on my C3700v2? 5ghz works fine.
Did it ever work?
What is the 2.4ghz led on the router showing?
did something change or were you changing anything?
- merncarAspirant
Thank you for your help! I dont think it has ever worked. I dont think I have changed anything. My devices that require 2.4 ghz have not worked since i bought this. The LED flashes on both the 2.4 and 5.
if you log in through the browser, can you check to see if the 2.4ghz wireless was disabled? What does it show on the status page for wireless settings?
