sheepherda
Sep 09, 2025Aspirant
My CAX80 started acting up
My CAX80 started acting up yesterday as well. No idea what changed but devices on 2.4 Ghz would work fine. Anything on 5 Ghz was sporadic connecting to the internet. Very frustrating when you work fr...
- Sep 10, 2025
Once it updated to the latest firmware 5.1.1.8 again over night, I was able to disable the Protectrion Engine and that appears to have resolved my issues.
Sep 09, 2025Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
What wifi channels are you using on the CAX80?
Try 1 or 11 on 2.4Ghz and 40 or 48 on 5Ghz.
Is Smart Connect enabled or disabled?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
Armor, Smart Parental Controls or Circle, IPv6, Protection Engine, Traffic Meter.
Has a factory reset and setup from scratch been performed since last FW update to v5?
