kevomac12's avatar
kevomac12
My CM-400, and I lost the orginal SSID, can't connect to my Fire Stick TV device!
Lost original SSID, I have mac and s/n, windows 10 home premium, and the DEFAULT username and password do not work!
HELP!!!
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    CM400 is not a WIFI device. you should have some other router. Ideally factory reset the router.
    • kevomac12's avatar
      kevomac12
      Sorry I mis-typed, I need to get the SSID to access my CM-400 (netgear) cable modem (I have MAC address, & S/N), to allow my Firestick, to access my AC-1200 (netgear) Wi-Fi router...to my cable modem and the internet!
      Can I get assitance to acommplish my objective?
      • antinode's avatar
        antinode
        Guru
           I don't see how.  An SSID is a wireless-network concept.  A CM400 is
        a cable-TV modem, only, and has no wireless-network interface.
           What, exactly, would you like to do?  What is your "my objective?"?
