Cyprian8981
Jun 03, 2016Aspirant
my netgear ac1750 modem/router model c6300
Just got the AC1750 C6300 Cable Modem router and it makes a thumping type noise, unless you turn it a certain direction. Anyone else have this? Or have any thoughts about it. Everything seems to be working ok, but it is annoying as all get out.
- DarrenMSr. NETGEAR Moderator
Hello cyprian8981
I would contact Netgear support about this as it may need to be replaced.
http://www.netgear.com/support/contact.aspx
DarrenM
- Cyprian8981Aspirant
I did just that and got a replacement(same model and everything). Bought it through amazon and got it returned through them as well. New one does the same thing. Very strange but doe not seem normal to me. Doesnt always do it though. Sometimes if I turn it a certain way it stops. Thinking maybe a different model :(
