johnfsiegel's avatar
johnfsiegel
Follower
Nov 15, 2015
My new Netgear C6300 won't connect to the WD Mycloud
WD MyCLoud has a green light indicating it's connected to the network, but doesn't show up on my PC or as being attached to the C6300. Worked until I switch to the C6300. Tried swapping cables, etc. If I switch back to the old router it works. Any known issues with C6300's not working and playing well with WD NAS?
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    Which ISP are you on?
    what FW are you running?
    are you trying to access WD Mycloud locally in your network (I think it still needs go to cloud and loopback)
  • Hi,
    i am having the same problem with my N300. if you have found a solution, kindly please share.
