Bamaboy
Oct 12, 2017Aspirant
My wireless network name changed
I am trying to connect to my Netgear router. The rounter name does not show up as an available network. The name Atheros_Span is listed as the network name.
DarrenM
Oct 18, 2017Sr. NETGEAR Moderator
Can you connect to the router via a Ethernet cord and log into the router and check the wireless settings see if the SSID was changed.
DarrenM
Bamaboy
Oct 19, 2017Aspirant
Thanks for the advise. I am not the greatest computer person. Will try though. Strange thing is that my Iphone still shows Netgear as the name of the router. My computer and printer show a different name. It has to be the same router because I turned the router off and lost the connection. I wonder if the other name is a default name. It shows a different speed as only 2.5 instead of 4..
