S_V_B
Nov 29, 2015Aspirant
N300 (Model C3000) No Internet, Power on, All Lights Flash Periodically
Hello all, I have an N300 C3000 that periodically lost internet connection until yesterday when it stopped receiving any signal at all. Typically, the device would lose internet and automatically...
S_V_B
Nov 30, 2015Aspirant
I cannot seem to access the modem via IP address or routerlogin.net. The browser simply returns not online/no internet connection. When I run the command ipconfig, the gateway network address is null which is disconcerting. Also, there are a number of lines that read "media disconnected". I tried running a few other commands suggested online to no avail. Also, I plugged into the unit to a neighbors coaxial and it appears to perform the same (power light steady green, then all lights flash every 15 seconds with power flashing red. Pretty much ready to throw the towel in and buy something else.
DarrenM
Dec 01, 2015Sr. NETGEAR Moderator
Shalake
If the downstream light is still blinking it means its not locking on so something is wrong with the cable signal I would say a tech would have to come out and adjust you levels.
S_V_B
Have you tried to do a factory reset and see if you are able to log into the modem? if so the modem may of had a failure since you are saying the power light is blinking red.
DarrenM
