RobnH's avatar
RobnH
N450 CG3000dv2 "LAN access from remote" log entries
Modem: Netgear N450 CG3000DV2
Firmware Version: V3.01.06
ISP: Time Warner
Hi folks,
I’m concerned about the “LAN access from remote” entries in the attached logs.  I do not know how to configure the router to block this access. I’m not even sure what device is being accessed.
Remote Management is off.
I’ve disabled UPnP.
There are no port forwarding/port triggering rules.
I’ve disabled the bulk of the services that were enabled when I hard reset the modem.
The admin password has been changed.
Wireless is disabled. (I have a DLink access point handling the wireless traffic.)
Guest Network is disabled.
No torrents are being run.
Any suggestions are appreciated.
Thanks!
-Robin
Description
Count
Last Occurrence
Target
Source
[TCP- or UDP-based Port Scan ]
2
Thu Nov 24 06:35:56 2016
172.xxx.xxx.xxx:59763
209.18.47.62:53
24
Thu Nov 24 06:30:13 2016
172.xxx.xxx.xxx:62922
209.18.47.61:53
[LAN access from remote ]
1
Wed Nov 23 21:52:08 2016
172.xxx.xxx.xxx:161
12.35.230.2:63433
3
Wed Nov 23 21:37:31 2016
172.xxx.xxx.xxx:22347
209.18.47.62:53
1
Wed Nov 23 21:10:53 2016
172.xxx.xxx.xxx:161
196.15.222.185:52181
10
Wed Nov 23 21:10:13 2016
172.xxx.xxx.xxx:57185
209.18.47.62:53
1
Wed Nov 23 17:56:46 2016
172.xxx.xxx.xxx:161
12.28.6.226:49679
7
Wed Nov 23 17:07:01 2016
172.xxx.xxx.xxx:35617
209.18.47.62:53
1
Wed Nov 23 07:43:10 2016
172.xxx.xxx.xxx:161
185.94.111.1:58981
1
Wed Nov 23 07:36:03 2016
172.xxx.xxx.xxx:20604
209.18.47.62:53
2
Wed Nov 23 07:35:40 2016
172.xxx.xxx.xxx:161
212.80.185.174:80
4
Wed Nov 23 07:31:25 2016
172.xxx.xxx.xxx:42479
209.18.47.62:53
1
Wed Nov 23 06:54:13 2016
172.xxx.xxx.xxx:161
184.105.139.67:30404
1
Wed Nov 23 06:43:12 2016
172.xxx.xxx.xxx:34215
209.18.47.62:53
1
Wed Nov 23 06:42:34 2016
172.xxx.xxx.xxx:161
185.128.40.162:51808
16
Wed Nov 23 05:31:39 2016
172.xxx.xxx.xxx:54957
209.18.47.62:53
1
Tue Nov 22 22:10:00 2016
172.xxx.xxx.xxx:161
80.82.64.42:49895
5
Tue Nov 22 22:00:49 2016
172.xxx.xxx.xxx:62649
209.18.47.62:53
2
Tue Nov 22 20:38:30 2016
172.xxx.xxx.xxx:161
89.248.168.6:18564
21
Tue Nov 22 17:30:26 2016
172.xxx.xxx.xxx:31657
209.18.47.62:53
1
Tue Nov 22 07:49:36 2016
172.xxx.xxx.xxx:161
204.42.253.130:56921
6
Tue Nov 22 07:41:18 2016
172.xxx.xxx.xxx:41197
209.18.47.62:53
  • Hi Robn,
    Yes - I'm having this issue too (and I replied to your post over at the TWC forum). So it looks like the combination of an N450 modem and Time Warner Cable is inviting remote attacks on our systems. I'm repeating myself from that TWC post here:
    I am seeing the same type of remote accesses on my N450 modem too. These accesses appear to be exploiting a vulnerability in the N450 SNMP stack as the accesses are all on port 161 (same as what your logs show). The remote IP's I'm seeing trace back to Russia, Sweden, and Israel. This looks very much like our modems are being commandeered for use in botnets.
    Unfortunately there is no way for the owner to control the WAN facing services so this problem must be fixed by Netgear (firmware upgrade) and rolled out by TWC. This is very troubling because I assume the attackers are able to hack systems on the LAN side once on the modem. I recommend powering off your modem when not in use - it will at least inconvenience the remote hackers. A dedicated firewall and new wap between the modem and your LAN devices will also help protect your personal systems but won't stop the modem from being used in botnets or as a beachhead to hack away at your LAN.
    I think that it is possible that TWC isn't sufficiently locking down remote SNMP access on their subnets. It's also very likely that the N450 is running an old version of SNMP - there are known vulnerabilities in older SNMP versions.
    Here's a link back to your TWC post for other TWC custoers to reply to if they see similar on their modems:
     http://forums.timewarnercable.com/t5/Home-Networking/LAN-access-from-remote-entries/td-p/119340
    Thanks.
    • mattf1856's avatar
      mattf1856
      Tutor
      I'm in the same situation with TWC.
      Would setting up a port 161 forward to an unused internal IP prevent this access?
      • RobnH's avatar
        RobnH
        Port forwarding was suggested on another forum. I set it up. It looks like the port forwarding activity should show up in the logs, but I have not seen it. I am continuing to see the "LAN access from remote" entries.  Please let me know if you have better luck.
        Thanks
