RobnH
Nov 23, 2016Aspirant
N450 CG3000dv2 "LAN access from remote" log entries
Modem: Netgear N450 CG3000DV2 Firmware Version: V3.01.06 ISP: Time Warner Hi folks, I’m concerned about the “LAN access from remote” entries in the attached logs. I do not know how to configu...
shuli
Feb 28, 2017Aspirant
Hello everyone. I am having this same issue of "LAN access from remote" but Cox Communications is my ISP. I am no expert but have read as much as I can, and the issue persists. Is it the general consensus of those in this discussion that the best solution is to buy a new modem and router? Many thanks for your insight,
mattf1856
Mar 02, 2017Tutor
The factory reset fix to stop the disconnects is still holding strong for me months later. I have no idea why it seems to work for some but not for others. I'm still getting the "LAN access from remote" entries about 3-4 a day from all over the world on port 161. I contacted Netgear support about this and they told me that a technician would be calling me to do some diagnostics. The call never came.
I assume this unit is going to be another Netgear modem that gets identified as being hopelessly insecure like the JNR1010v2 / WNR614 / WNR618 / JWNR2000v5 / WNR2020 / JWNR2010v5 / WNR1000v4 / WNR2020v2 / R6220 / WNDR3700v5 units. I just ended up buying a replacement from a different company, I just have yet to get it installed.
