njh3's avatar
njh3
Follower
Jun 14, 2018
N450 CG3000Dv2
My network name was not showing up on my list of networks, so I tried resetting my N450 modem/router, which has worked in the past. Instead of restoring factory defaults, it has renamed the network CG3000DV260, and neither the factory default password, nor the one I had changed it to previously, will let me access it. Can anyone help?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    You may need to do the factory reset then try the defaults.
    DarrenM
