unsnapped_beef
Jul 06, 2017Aspirant
N450: lack of gateway options
TL;DR: My NETGEAR Gateway AND Genie do not give me the option to access my wireless settings. I recently went through a long process of getting my router/modem connected to Spectrum. I have inter...
unsnapped_beef
Jul 08, 2017Aspirant
They may have changed it to bridge mode. The woman I talked with had mentioned that. I'm contemplating getting just a router and reactivating their modem. She made it seem as though all I had to do was plug it in and go.
vkdelta
Jul 08, 2017NETGEAR Employee Retired
Spectrum will do all these tactics to force you into leasing their modem and WIFI router.
Can you call them to re-activate your WIFI on your N450 device?
what FW you have running on your device?
- unsnapped_beefJul 08, 2017Aspirant
The WiFi is activated on the N450. Though only some devices can connect. My Xbox is connected. My phone was connected but now it wont. My fiance's phone is connected.
is "FW" firewall?
- vkdeltaJul 08, 2017NETGEAR Employee Retired
FW = Firmware.
what is the Firmware version on the device?
