lawsonde's avatar
lawsonde
Follower
Oct 02, 2015
N450 trouble after self test
CG3000Dv2 the red lights were flashing signalling a self test, and afterwards, it will not broadcast wifi signal. The wifi light is on, everything appears normal, but I cannot find the network on any of my devices. Any help?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Lawsonde
    go into the router and make sure the SSID is being broadcasted under Advanced then wireless settings if ti is and still can see the Wifi do a factory reset. see if that works.
    DarrenM
