Simon8
Aug 16, 2022Follower
N450/CGV3000DV2 - L2PT error when connecting to VPN
Connecting to employer's VPN via wi-fi on N450 gets error: L2TP connection attempt failed because the security layer encountered a processing error during initial negotiations with the remote computer.
This problem started on Friday. IT team tried to resolve, and until they could check everything out, they suggested that I try through my mobile hotspot. I was able to get onto VPN via my phone's mobile hotspot.
On Monday, I tried to connect via mobile hotspot and got the L2TP error. IT did a lot of troubleshooting and checking into everything on their end and was unable to resolve but could confirm that everything on their end looked ok. Advised to call Comcast. Comcast said there is nothing on their end stopping this and that I should check my router. Employer has checked everything on their end. Comcast won't check my router because I own it. Today I connected via ethernet and could get onto VPN. Then disconnected ethernet and tried via wi-fi and it connected to VPN. After a couple hours, the VPN disconnected and I cannot reconnect to VPN via wi-fi. I get this same error.
Can anyone help? Thank you!
1 Reply
- olympos1625NETGEAR Employee Retired
Hi Simon8,
Thank you for reaching out. We are sorry to hear about your experience with the modem. I would like to verify some details. Was this setup working properly before without getting disconnected from the VPN or has it happened from time to time since the beginning? Please DM me the serial number of the modem. Where did you purchase the modem? What is the current firmware of the modem? Aside from the issue of the VPN, are you experiencing any disconnection from the internet on your devices when connected to the modem?
I am looking forward to your response.
Oliver
Community Team
