Bouchnet's avatar
Bouchnet
N600 C3700 Modem/Router settings in Router not routing via OpenDns network per configuration
The dns settings in the router have been set to:
208.67.222.222
208.67.220.220
208.67.222.220
Problem is that any device useing router should be routed through these settings but it’s not working.  I’m stumped.
  • How are you determinine that your connected devices are not being routed thru these DNS addresses?
    All DNS seen on the LAN side will have a 192.168.0.1 address probably and thus will be routed thru the C3700 and the DNS set there...
  • FURRYe38's avatar
    • Bouchnet's avatar
      Bouchnet
      Solved.  Using the Genie App, I setup Parental Controls option and from there it connected to to my OpenDns account.  Within the app I rebooted the Router and now all my devices are using OpenDns.  Thanks for your help.
