jschramm76
Jan 16, 2016Initiate
N600 C3700 Wifi Speeds Slow
I have an N600 C3700 cable modem/wifi router, and I am having trouble with the speed of my wifi connection. I have Comcast Blast 150Mbps service, and my wired connection typically gets 175-180Mbps (t...
Ripleey
Mar 17, 2016Tutor
I have read a lot here and made many changes to the setting for this modem as well as several others that seemed promising. Nothing helps.
I have even changed the MTU settings. I am having no luck. Looking for ANY assistance with this from the community or Netgear.
- DarrenMMar 29, 2016Sr. NETGEAR Moderator
Hello Ripleey
What kind of speeds are you getting over wifi?
DarrenM
- RipleeyMar 29, 2016Tutor
Mostly around 60mbps. I sent the router back and got a new one. When I plugged it in and got it set up, I got ONE reading of 160mbps and then it dropped again. Seems very very random when the speed is higher than 60, but never above 80.
Have you tried to adjust the wireless channel in the wireless settings? also do you have a older wifi device that connects to your network?
DarrenM
