Wifi Slow
1 TopicN600 C3700 Wifi Speeds Slow
I have an N600 C3700 cable modem/wifi router, and I am having trouble with the speed of my wifi connection. I have Comcast Blast 150Mbps service, and my wired connection typically gets 175-180Mbps (testing with both Speedtest.net and Xfinity's speed test site). However when on wifi I typically am getting 25-30Mbps on the 2.4GHz channel and maybe up to 50Mbps on the 5GHz channel. I’ve tried on two different android phones, two ipads, and a macbook air, and all have those same slow results over wifi. Tested when within about 3 feet of the router, all the way to 20 feet away. I have run the tests dozens of times over the past several days and those results are consistent. I have checked all the settings on the router and all appear to be per Netgear recommendations. I am using WPA2-PSK [AES] security and both 2.4GHz and 5GHz are set to the “Up to 300 Mbps” mode (I understand I'm not going to get 150 Mbps on 2.4 GHz, but I think I should get it on the 5 GHz). There are no neighboring wifi signals on the channels I am using so it is not an interference issue, nor are there any other possible interference signals in my home that I am aware of. I have tried disabling the encryption and still get the same speed. This morning I did a factory reset and confirmed I’m on the latest firmware (v2.02.06) and I still have the same problem. Any guidance on how to increase the wifi speed?22KViews5likes16Comments
