jschramm76
Jan 16, 2016Initiate
N600 C3700 Wifi Speeds Slow
I have an N600 C3700 cable modem/wifi router, and I am having trouble with the speed of my wifi connection. I have Comcast Blast 150Mbps service, and my wired connection typically gets 175-180Mbps (t...
DarrenM
Mar 29, 2016Sr. NETGEAR Moderator
Hello Ripleey
What kind of speeds are you getting over wifi?
DarrenM
Ripleey
Mar 29, 2016Tutor
Mostly around 60mbps. I sent the router back and got a new one. When I plugged it in and got it set up, I got ONE reading of 160mbps and then it dropped again. Seems very very random when the speed is higher than 60, but never above 80.
- DarrenMMar 29, 2016Sr. NETGEAR Moderator
Have you tried to adjust the wireless channel in the wireless settings? also do you have a older wifi device that connects to your network?
DarrenM
- stubbyMar 29, 2016Guide
I have consulted with my business IT guys and worked through different
channel options with no improvement.
No older devices on the network, all iPhone 5s or better and G or N PC wifi
devices. Issue of wifi speed is the worst on 2.4 network, but typically
cripples both 2.4 and 5 ghtz down to 1 or 2 mbps at random times throughout the day.- DarrenMMar 30, 2016Sr. NETGEAR Moderator
Do you have Time Warner cable? if so I do know there is a new firmware that is being certified for the c3700 so it should be coming out soon but I do have a ETA on this.
DarrenM
