jschramm76
Jan 16, 2016Initiate
N600 C3700 Wifi Speeds Slow
I have an N600 C3700 cable modem/wifi router, and I am having trouble with the speed of my wifi connection. I have Comcast Blast 150Mbps service, and my wired connection typically gets 175-180Mbps (t...
c3700
Apr 25, 2016Aspirant
Same issue, I have tried all the options, but the speed is not up.
c3700
Apr 26, 2016Aspirant
Update on the wifi slow.
try these, irrespective of 2.4 or 5,.
1) try to check the wireless channels available/used near by you. app will show other users who use the wireless channel (use any of the Wifi Analytics App. netgear has this android app)
2) go to your router admin page
3) Wireless -> whichever GHz you use either 2.4 or 5, change the channel(do not use Auto) which no one use near by you and save/apply
try check the speed now.
I tried this and the speed apprx 25-30 mbps which is double than what i got previously. ofcourse the wired speed is not reached as wireless always gives the 50-60% of the actual speed
