jschramm76
Jan 16, 2016Initiate
N600 C3700 Wifi Speeds Slow
I have an N600 C3700 cable modem/wifi router, and I am having trouble with the speed of my wifi connection. I have Comcast Blast 150Mbps service, and my wired connection typically gets 175-180Mbps (t...
CritCare
Jul 18, 2016Aspirant
I just purchased this Wifi Router. I am incredibly dissappointed with Netgear. I can't obtain any speed higher than 45Mbps, even after attempting all the adjustments listed in these threads. I still have my rental modem/router from Comcast. I plugged their's back in to see if this was a connectivity issue, but it's not. I get close to 90Mbps speeds on the Comcast modem/wifi router.
Netgear/Darren, do you have any suggestions?
- DarrenMJul 21, 2016Sr. NETGEAR Moderator
Hello Critcare
I would suggest contacting Netgear support so they can troubleshoot and work with you more to see if its a issue with the modem.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
