servotsc
Jan 11, 2016Aspirant
N600 cable Modem with voip system
I purchaced a n600 cable modem / router unit to swap out my cable company modem and simplify my network. Currently i have the cable co provised modem conencted to my voice system which needs an exter...
DarrenM
Jan 13, 2016Sr. NETGEAR Moderator
Hello servotsc
I do not believe that you can just have one port on the Moden router do that but are you able to open ports or put the voip in the DMZ so it will work while connected to the N600?
DarrenM
servotsc
Jan 19, 2016Aspirant
Wouldnt it be a security risk to put it on the dmz? Any way i had to return the modem my isp would not allow me to have that unit they say it was not supported.
