elgatodog
Jan 25, 2016Aspirant
N600 DGND3700 | Windows 10 | Drivers
 Hi,  I upgraded a new PC from windows 7 to windows 10.  Everything was working fine with the modem router previously but once upgraded to windows 10, the pc cannot find the drivers for it.  I cannot ...
Babylon5
Jan 25, 2016NETGEAR Employee Retired
- Netgear routers don’t need drivers, if they did then that would imply that one PC on the network would be a ‘controlling’ PC, that’s not the case. I am aware that others in the past have seen similar Windows messages about drivers, please post a screen grab of the message if you can.
 - Firmware needs to be extracted from the .zip file, this should typically contain the firmware and installation instructions. The file to be uploaded to the router is typicaly a .chk file. I suggest that we resolve the issue above first as firmware update isn’t a likely solution.
