elgatodog
Jan 25, 2016Aspirant
N600 DGND3700 | Windows 10 | Drivers
Hi, I upgraded a new PC from windows 7 to windows 10. Everything was working fine with the modem router previously but once upgraded to windows 10, the pc cannot find the drivers for it. I cannot ...
Babylon5
Jan 25, 2016NETGEAR Employee Retired
- Netgear routers don’t need drivers, if they did then that would imply that one PC on the network would be a ‘controlling’ PC, that’s not the case. I am aware that others in the past have seen similar Windows messages about drivers, please post a screen grab of the message if you can.
- Firmware needs to be extracted from the .zip file, this should typically contain the firmware and installation instructions. The file to be uploaded to the router is typicaly a .chk file. I suggest that we resolve the issue above first as firmware update isn’t a likely solution.
elgatodog
Thanks Andy, I greatly appreciate your response.
I've copied in a screenshots of the various messages below.
Gordon
- Babylon5Jan 25, 2016NETGEAR Employee Retired
All those screen-grabs seem to relate to the computer’s network adaptor. If you take a look at the Device manager it should identify the actual device number that’s missing the driver, for example;
- elgatodogJan 26, 2016Aspirant
Hi Andy,
In device manager the network adaptors all come up as working properly, but the ethernet controller comes up as not working.
I have inserted screen shots below.
I have tried uninstall of the ethernet controller and restarting but the wizard does not commence. Instead a message comes up with the netgear logo that says the service is not available.
Thanks.
Gordon
- Babylon5Jan 26, 2016NETGEAR Employee Retired
Is this a purpose built computer or one bought from a shop? If the latter I would expect you to have manufacturer’s driver disks or for drivers to be available at the manufacturer’s website. Is there a model number / specifications for the computer?
When the driver for the Ethernet Controller is properly installed and working then in Device Manage it should transfer to one of the other categories, in this case it would then normally appear as a Network Device.
