elgatodog
Jan 25, 2016Aspirant
N600 DGND3700 | Windows 10 | Drivers
Hi, I upgraded a new PC from windows 7 to windows 10. Everything was working fine with the modem router previously but once upgraded to windows 10, the pc cannot find the drivers for it. I cannot ...
elgatodog
Jan 26, 2016Aspirant
Hi Andy,
It was built for me by pc case gear in Australia.
Everything was working fine prior to upgrade to windows 10.
Thanks.
Gordon
Babylon5
Jan 26, 2016NETGEAR Employee Retired
OK, well you need to find out what the network device is. If it’s fitted to the motherboard (the connector at the back of the case is on the motherboard) then the driver can normally be downloaded from the motherboard manufacturer’s website. If it’s a separate network card (less likely) then the driver should be available from the card manufacturer’s website. Or you could contact the company that built the PC, which is probably the quickest solution.
- elgatodogJan 27, 2016Aspirant
Hi Andy,
That makes sense. Thanks for your help. I will contact them.
Gordon
