jcortes63
Jun 13, 2015Aspirant
N600 docsis 3.0 wifi cable modem router static table size
Seems to be this router does not allow to create static ip address out of the scope of DHCP, I decided to create a range of static IP addresses using fictitious mac address in the upper section of DH...
Babylon5
Jun 13, 2015NETGEAR Employee Retired
Can you say which model of router you own please? N600 is a generic term.
There will be a limit on the number of Address Reservations that a router will allow, this can vary between models but is in the order of magnitude that you see i.e. 10 or 20 are typical limits.
