jcortes63
Jun 13, 2015Aspirant
N600 docsis 3.0 wifi cable modem router static table size
Seems to be this router does not allow to create static ip address out of the scope of DHCP, I decided to create a range of static IP addresses using fictitious mac address in the upper section of DH...
Babylon5
Jun 14, 2015NETGEAR Employee Retired
I believe the C3700 is an ISP provided router, Netgear can only change firmware with the agreement of the ISP, and the ISP decides on the feature set.
