skiddles6969
Jun 26, 2017Aspirant
N600 Ports not communicating with PC
My router ports stopped workiing/communicating with my PC. I tried resetting the port, resetting cable modem, restarting PC, Inone worked. It still won't detect on PC, however, when I bypass router a...
DarrenM
Jun 28, 2017Sr. NETGEAR Moderator
Hello Skiddles6969
Do you have another device that connects via ethernet that you can try and test it with?
DarrenM
skiddles6969
Jun 29, 2017Aspirant
Hi Darren,
Yes, I tested it with a laptop. I got the same error message. I reset the router, and still no communication with the PC or the laptop.
- DarrenMJun 30, 2017Sr. NETGEAR Moderator
Hello Skiddles6969
Have you done a full factory reset on the unit? if so you may want to contact support if the modem is under warranty.
http://www.netgear.com/support/contact.aspx
DarrenM
