skiddles6969
Jun 26, 2017Aspirant
N600 Ports not communicating with PC
My router ports stopped workiing/communicating with my PC. I tried resetting the port, resetting cable modem, restarting PC, Inone worked. It still won't detect on PC, however, when I bypass router a...
skiddles6969
Jun 29, 2017Aspirant
Hi Darren,
Yes, I tested it with a laptop. I got the same error message. I reset the router, and still no communication with the PC or the laptop.
DarrenM
Jun 30, 2017Sr. NETGEAR Moderator
Hello Skiddles6969
Have you done a full factory reset on the unit? if so you may want to contact support if the modem is under warranty.
http://www.netgear.com/support/contact.aspx
DarrenM
