amit_m12's avatar
amit_m12
Follower
Jul 16, 2016
N600 WiFi Cable Modem router (For XFinity VOIP)
Hi,
I have N600 WiFi Cable Modem router. It has 1 USB and 2 Ethernet port. I recently shifted to Xfinity voice. However I am unable to connect to the router/modem as it requires a telephone port for connect my phone device.
Is there a way I can achieve the same?
Thanks
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello amit_m12
    Netgear modems do not have hook up for phone so you would have to use a separate mode from your ISP to use the phone.
    DarrenM
