leoverlord's avatar
leoverlord
N600/C3700 - Modem/Router - Wont go into Router Mode
My n600 c3700 modem/router stays in bridge mode only. When i go into the netgear genie, using the standard ip 192.168.100.1 I'm giving very limited options... One under advanced in router mode, and its off... When i attempt to turn it on the genie tells the modem to reset and go into router mode but something happens during/after reboot because it will remain in router mode off (bridge mode) only... Im curious to your solution to my problem
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Have you tried to unplug the cable cord from the modem before doing this they after the reboot connect the cable cord again.
    DarrenM
    • leoverlord's avatar
      leoverlord
      Yeahup I've tried on and off, rebooting the modem, factory reseting it through the genie and on the modem... nothing, it will not go into router mode
      • DarrenM's avatar
        DarrenM
        It could be a issue on the ISP side if they have the coding wrong for the modem it could have it locked as only a modem.
        DarrenM
