RoseySofty's avatar
RoseySofty
Follower
Feb 05, 2016
Neatgear Gateway c3700-100NAS
Unable to connect to PSN Playstation says firewall issue comcast says set to dmz and port porwarded all ports nether worked.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Roseysofty
    You should be able to make the NAT open on the playstation by port fowarding or having it put in the DMZ. Here is some article plus the ports you need for the PS4 may want to try again.
    Application                      TCP Ports                                              UDP Ports
    PlayStation 4          80, 443, 1935, 3478-3480                         3478-3479
    http://kb.netgear.com/app/answers/detail/a_id/1118
    http://kb.netgear.com/app/answers/detail/a_id/24046
    DarrenM
